Correct form for a diameter dimension across an non-visible center
How do you correctly display a diameter dimension in a view [say like a detail view] where neither the opposite projected line/surface nor the center line are visible?
RE: Correct form for a diameter dimension across an non-visible center
I have used a double arrowhead to get the point across.
I have no idea if that's standards-compliant.
Mike Halloran
Pembroke Pines, FL, USA
Show an image of your dwg?
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
You don't.
Put the dimension where the feature being dimensioned is unambiguously shown.
double arrowhead or a jogged arrow are accepted, though as Mint says, better to use an unambiguous detail even if you have to add an extra view just for that one detail.
Jim Sykes, P.Eng, GDTP-S
Profile Services  www.profileservices.ca
TecEase, Inc.  www.tec-ease.com
