Verify vacuum pump information
This is the information I got from an OEM.  4.0 CFM looks too low to me.  Can someone help me verify it?
Based on evaporation rate of 140 lb/hr at 26"Hg Vacuum, the following is what the vacuum pump should be sized for (this info can be sent to a vacuum pump vendor):
Service Vapor:                                                 60 wt% Ethyl Alcohol, 40 wt% Water (estimated)
Free Dry Air:                                                     1.5 lb/hr
Vapor Temperature:                                      90ᵒF
Suction Pressure at Vacuum Pump:            1.84 psia
MW:        39.2
Seal Water Temp (if required):                    80ᵒF (to be verified)
Volumetric Flow at Vacuum Pump:            4.0 ACFM
