Need Help! - Antiterrorism Design for Military Facility
I will be very vague as I'm sure they're listening... (joking) I am currently working on an military installation and we are adding some ventilation openings in existing masonry walls (that are NOT designed for blast resistance) however, the design team has been reinforced several times by the Army Core that we need to make sure our design meets the criteria of UFC 4-010-01 standard for Antiterrorism.
What I cannot conclude from reviewing this document is other than a minimum height requirement of 10' AFF is what else I need to do. I feel as though their may be some requirements as far as the connection of the mechanical equipment in the opening to the masonry walls but I am at a loss. Could any chime in and maybe help provide some direction as to what UFC document or other DoD standard might pertain to this issue or how maybe provide some direction as to the design I would need to include (i.e. blast loading). Thanks.
RE: Need Help! - Antiterrorism Design for Military Facility
Are these load factor's intended to be stacked on the DL factor for LRFD design per ASCE 7 (1.2)?
Also, these buildings do not meet the requirements of standoff distances, however we have been directed to reference UFC 4-010-01. Does this mean I brace the mechanical equipment as referenced or are my loads higher because the standoff distances are not met and if so, what document is that information in?
Thanks again.
