Sensor Signal Conversion
Greetings,
I am trying to make a circuit that converts an analog pulse 0-4.5 volts sinusoidal (0- 3600 pulses per minute) to a voltage 0- x signal.   Take that voltage signal and use that to proportionally amplify a 0-2.5volt signal to 0-5 volts.
Could anyone recommend a circuit to accomplish this?
Art K.
RE: Sensor Signal Conversion
By the time you get through buying and tuning all the analog components, it will be cheaper to use a microntroller with two analog inputs and one analog output.
For the 0-3600 ppm input, since all you care about is the edge rate, you could just use a digital input for that instead of one of the analog inputs.  If the signal is at all noisy, you may need to add a Schmitt trigger or debounce it in software.
Mike Halloran
Pembroke Pines, FL, USA
Mike,
Thanks for the reply.  I am an ee nube. Could you please recommend an ots board I could connect to and program with this capability?
Art Koral
Maybe if you tell us a little about what you _do_ know, the local propellerheads will suggest something.
Mike Halloran
I am a fairly savy aerospace and mechanical engineer.  I can program and learn languages as required. Understand basic circuits and power electronics.   Have worked on plcs to a very limited extent.
Further previous post: but if your sine signal change amplitude with constanr frequency, than you need peak detector.
