GFI on main service
GFI on main service
Hello, I have an installation at 600V that requires ground fault protection (RCD) on the main service disconnect. I have designed it with fuses, but obviously fuses have no RCD. As a GFI breaker at this size would be very expensive, has anyone heard of a stand-alone zero sequence transformer and interrupting circuit? (Yes, essentially a breaker without the thermal/mag trip).
Thanks for your time
RE: GFI on main service
Most of the major mfrs sell them, do a search using the term "Ground Fault Relay", GFCI is something different.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I have found a GFR with a neutral cond. C/T. Considering the GFR is still just a signalling device, I still require an external interrupting device (moulded case switch). With this setup I still require OCP by means of fuses upstream. Seems to me this setup will be overcomplicated and cost more than just buying switchboard with a GFI MCCB. Thoughts?
Thanks for your time,
The decision to use fuses or circuit breakers is one that elicits a lot of debate, but in general if you used fuses for current limiting and/or very high interrupt capacity, you may not be able to replace them with an MCCB. There's more to it than just the ability to shunt trip it.
.. and yes I have the disconnect on the supply side of the fuses. Always good practice to be replacing fuses on live conditions.
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". – Nikola Tesla
Good on ya,
Goober Dave
Another provider is www.boltswitch.com
