Create a standalone MATLAB exe
Hi everyone!
I've written a MATLAB code, with 3 functions and some output PLOT.
How can I create a standalone .EXE for a Matlab code? Is it possible?
Thanks in advance
RE: Create a standalone MATLAB exe
Thanks! But what code should I write in Matlab to generate an EXE file??
You need to buy the (named for historical reasons) Matlab Compiler. It doesn't generate C code any more - hasn't done for many years. It allows you to create a hugely ugly and bloated runtime environment tha emulates Matlab and then runs your code in it. It's a deployment tool, used for sharing Matlab code with those who either have no license of their own, or for those who you want to keep source code secret from.
- Steve
You need something called the MCRInstaller.  Have a look at http://www.mathworks.com/access/helpdesk/toolbox/compiler.  There is a sort of crib sheet there that tells you how to convert from .m files to executables.  You need to have a C/C++ compiler accessible.
Thank you very much!
