240 Volt Transformers
If we have a transformer that takes 600 volt down to 240 volt, 1 ph 60Hz, is there any issue running a 230 volt device, 1 ph, 60 Hz? I have been told a "rule of thumb" is +/-10% is fine.
Any help would be greatly appreciated
RE: 240 Volt Transformers
Generally, there is no problem. As you said, most devices can handle supply voltage variation of +/-10%. You can also look at the allowable input voltage range of the equipment.
http://www.powerqualityworld.com
Standard motor voltage ratings are multiples of 115 Volts.
Standard system voltage ratings are multiples of 120 Volts.
Bill
"Why not the best?"
Jimmy Carter
