How to keep cylinders from reversing themselves
Hello all,
We use quite a few hydraulic & pneumatic cylinder assemblies in our assemblies as "flexible" models for mating purposes. Many times when moving the upper level assemblies through their degrees of freedom the cylinders reverse themselves (rod & cylinder body are facine away from each other). When we build the cylinder assemblies we always have the rod body and the cylinder body concentric with each other. When they reverse themselves they maintain the concentic mate but the concentric mate should not allow them to "un-mate and then mate again". Is thee a way to prevent this from happeneing while still using them as flexible assemblies? It is really becoming counter-productive.
Thanks.
Thanks.
www.phoenixdyno.com
Home of the world's most accurate and repeatable dynamometers, dynamometer accessories, and data acquisition & control software.
RE: How to keep cylinders from reversing themselves
Dan
www.eltronresearch.com
Dan's Blog
Eric
www.phoenixdyno.com
Dan
Dan's Blog
- - -Updraft
Look at the mate order.
Re-order the mates just for the cylinder.
Mates are solved in sequence one at a time. If a flippable mate is solved first that could be the problem.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
