shaft &bearing currents
Hello everybody,
What is shaft and bearing current? How does it occure? What are the indications? How can you measure? is there any thread about this topic before?
Thanks in advance.
zub.
Thanks in advance.
zub.
RE: shaft &bearing currents
Pardon me, but please have the simple courtesy to spend a few minutes in a search.
I'm actually keeping in search but i couldn't find a right source. i have found two papers on the situation. (One from ABB, one from SIEMENS) But they are global overview on the subject. I want to find something on the theoretical part. Most probably you have better resources, thats the reason why i am asking to you. And of course i don't have a good english to choose the right words while talking. But i am sure that you can tolarete this?...
Thanks again...
zub.
cheers Johnspark
Thread237-11607
Thread237-18455
Thread237-19830
Thread237-5626
Thread237-30254
Thread404-10671
Thread404-22856
zub, language aside, the skill for keyword guessing for an online search seems to be as much "art" as it is "science." It’s trying to think on the same terms as the author, and that can be difficult in any language.
http://www.ab.com/drives/techpapers/ieee/ieee.html
shaft and bearing current of rotating machines; just a hint, a keyword "electrical knittings"
There has been a lot of research done in this area. This problem is common to all varible frequency and DC drives that use power electronics. Look up on the web for a bearing fluting and you can get a lot of answers.
1-On what type of maching are using this motor ?
2- Are you taking about cluch & Brake slipring to control a milling machine ? This type is used to control speed and braking and is mounted to the end of shaft of the motor.
You checked ABB websight and they do have some info,most of it very generic.
The problem of circulating shaft currents are not limited to the use of VFDs (Hi-switching IGBTs),they may be present on any rotating machinery that has the capability of creating Static Electricity discharges.
The most common cause of CCurrents may be an Assymetrical magnegtic field.Most of our motors on VFDs, have either insulated NDEnd bearing housings, or we have shafts that have a brush rigging to Bypass the NDEnd bearing.
In some cases ,people have done all of these things and the bearing problems still persists.In other cases, people have changed greases to conductive types, which may help .On very stuborn cases of very critical machinery people have opted for bearings with porcelane elements.Very expensive i would guess.
I guess I am fortunate in the fact that over 30 years in the Electric motor business,I have seen very few (less than a handful) bearings failed due to flutting.
In addition to the above,I read some info to the fact that a rotating bearing at times behaves much like a capacitor. Its races being one plate and balls or rollers the other ,with a dialectric separator grease.
If you have a problem ,it can be very complex to solve.
Thank you
GusD
This past week I had the opportunity to test 4 new 600 hp /600 volts motors to be used on VFDs.
I noticed that all the NDEnd bearings (ball)had a bearing "outer race" that was coated with a ceramic material.We purchased similar motors 6 years ago that were equiped with shaft ground brushes.I like this new idea better than the ground brush.
I had not seen one of these bearings before, much less have one in my hands until last week.
Of all the methods that are used to mitigate shaft currents,this one may very well be the best.
I do not know if these bearings are a lot more expansive than standard bearings.
GusD
