Changing the *SLIDE LINE smoothing parameter after step
Hello Everyone,
I have a model comprised of CAXA4R2 elements and ISL21A contact elements. When defining the *Slide Line, I specify a smoothing parameter of 0.3, however I would like to decrease this smoothing parameter upon completion of the first step.
I considered using the *MODEL CHANGE keyword, but it seems that can only be used to replace elements.(slide line is defined as nodes)
1st step: resolve overclosures
2nd step: apply bending moment
Any help is greatly appreciated,
Dnov
Dnov
