Drilling auger cast piles against an existing building
How close can a 16" diameter auger cast pile be drilled to an existing building?
RE: Drilling auger cast piles against an existing building
It depends on the type of drilling equipment that the contractor uses.  Check with a local contractor that installs ACP's.
www.PeirceEngineering.com
