Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I've gotten solutions within a day - it saved a lot of time and actually got me one ATTABOY from my boss..."
Geography
wfsymon (Industrial)
27 Oct 11 6:24
hai to everyone,
I need an idea for solving the following issue.
Its full of pneumatic signals.
1. A level switch mounted on the tank and having an pneumatic signal as input and gives an pneumatic output when level reaches high.
2.I have a Pnuematic actuator with valve in the outlet line of the tank,
3. Now if level high the valve should open and if the level low (means no output from the level switch) the valve should close.
So can anyone help me how to and what will be reuired to solve this.
the switch output will 15 psig
thanks,
symon
jmw (Industrial)
27 Oct 11 8:23
By implication you don't want anything other than pneumatics?
And, you want the high level switch simply to protect the tank against overfill or does it runout the contents all the way down to the low level switch?
If it simply protects against overfill or running dry, then what about hysteresis?
In any event, the simple answer is to Google Fluidics and go from there.
Pretty well anything you can do with relay logic you can also do with fluidics.
So once you have your control logic worked out you can implement it using fluidics. At least, with a simple level control function you can.
And to see what can be done with plastic pipe, empty lemonade bottles and simple fluidic switches, see Theo Jansen
Try Tippets Fountainsfor some background and insight into the use of fluids.
JMW
www.ViscoAnalyser.com
30 Oct 11 4:04
Thanks to all,
i got the solution ,as if am using the pilot valves for operating the valve..
thanks
Close Box
Join Eng-Tips® Today!
Join Us             Close
