*CLOAD with Orientation
Hello everybody
I would like to know if its possible to apply a CLOAD with a given orientation.
By using DLOAD I can give a predefined orientation, but i would like to use a concentrated load. Is it possible?
If not, what is the best way to apply a 200N load to a defined nodeset? Creat a surface an use DSLOAD or simply DLOAD? In this case, which load type should I use?
Thanks a lot in advance!
RE: *CLOAD with Orientation
Thanks in advance!
