Metallic coupling
Metallic coupling
Metallic coupling
I am supplying a centrifugal multistage pump. My customer is asking for a metallic coupling with spacer. Could I offer him an elastic coupling with spacer and rubber blocks? Cast iron coupling is also accettable?
RE: Metallic coupling
Horizontal or vertical pump?
Carrying thrust load or not?
Rigid or flexible?
What HP, RPM and pump shaft diameter?
I would offer something like the Thomas DBZ series, that's likely what he wants.
