Retrofit Anchor Bolts for Residential Shear Walls
Since the advent of App. D, the task of holding down shear walls to existing residential foundations has become daunting. I am faced with yet another project where I can't get any anchor to work for even the small loads (2 - 3k wind, 1.5 - 2k seismic Cat D) on this project. The existing foundation is 6" wide concrete. I have looked at straps on the exterior as well as traditional PHD type holdowns. What are other engineers using in this situation?
RE: Retrofit Anchor Bolts for Residential Shear Walls
Mike McCann
MMC Engineering
