Analysis of 1978 Flexicore Slab using Current ACI criteria
I have a hollow-core precast slab that was installed circa 1985.  We have the structural drawings, that indicate the slab is 6", with a 2" structural topping.  The slabs are 2' wide, so we suspect it is a Flexicore.  We have the design loads, but unfortunately, the design loads work for even the least stranded hollow-core slab from the 1978 Flexicore safe load tables.  In short, we would like to analyze the T624A-D20 strand designation from that very manual, using current ACI criteria.  We need to obtain around 10-15 additional psf, and I think we can, but I need to run the numbers to make sure.  Can anyone provide asssitance on this, or point to an analysis spreadsheet that could assist?  I greatly appreciate your time and consideration.
