Get all components in an assembly
Does anyone know an easy way using NXOpen to get all the components in an assembly (including subassemblies) saved to an array? I like to sort the assembly tree in descending order and then export it to a spreadsheet. I would ideally like to get that same structure/order, but I need it in NXOPen variables so that I can manipulate the data.
RE: Get all components in an assembly
http://www.eng-tips.com/viewthread.cfm?qid=264052
http://www.eng-tips.com/viewthread.cfm?qid=308802
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
lw.Open()
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
If Not IsNothing(c.RootComponent) Then
'*** insert code to process 'root component' (assembly file)
lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'*** end of code to process root component
reportComponentChildren(c.RootComponent, 1)
Else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
End If
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
lw.Close()
End Sub
Sub reportComponentChildren(ByVal comp As Component, ByVal indent As Integer)
Dim numOccs(-1) As Tag
For Each child As Component In comp.GetChildren()
'*** insert code to process component or subassembly
lw.WriteLine(New String(" ", indent * 2) & child.DisplayName & vbTab & child.Name)
Try
ufs.Assem.AskOccsOfPart(comp.Prototype.OwningPart.Tag, child.Prototype.OwningPart.Tag, numOccs)
lw.WriteLine(New String(" ", indent * 2) & "Quantity: " & numOccs.GetLength(0))
Catch ex As System.NullReferenceException
lw.WriteLine(New String(" ", indent * 2) & "*** Component quantity information unavailable (component not loaded)")
Catch ex As ApplicationException
End Try
'*** end of code to process component or subassembly
If child.GetChildren.Length <> 0 Then
'*** this is a subassembly, add code specific to subassemblies
lw.WriteLine(New String(" ", indent * 2) & _
"* subassembly with " & _
child.GetChildren.Length & " components")
" + Active Arrangement: " & _
child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
'*** end of code to process subassembly
Else
'this component has no children (it is a leaf node)
'add any code specific to bottom level components
End If
lw.WriteLine("")
reportComponentChildren(child, indent + 1)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
www.nxjournaling.com
