NX and NASTRAN, different result with IGS import or NX part
Dear all,
I've posted on UG/NX forum but it's probably more appropriate here, sorry for double posting
I'm quite new with NX/NASTRAN(7.5) package but I have a small FEA background.
I'm doing some practical testing to learn how to use NX with NASTRAN.
I'm getting bogged on a simple I beam made with 2D shell elements.
Simulation is quite simple : I beam with pivot ends and tranversal force. It's just bending !
When I draw my beam with an other CAD software(Rhino) and import IGES in NX simulation, everything run ok, hand calculation give same result.
But when I draw my beam with NX (I tried everything in a part or assembly, same result), with the same way of preprocessing, result are stranges with different stress on top or bottom (near 20% difference!).
http://files.engineering.com/getfile.aspx?folder=dc9ef321-b62a-4b98-8db6-c15445a4fe03&file=nx_beam_2D_element.JPG
Thanks for your help
Mitch
RE: NX and NASTRAN, different result with IGS import or NX part
On MSC Nastran, there is a .dat or .bdf that contains all the model details.
On NX Nastran, I would compare the two files that contain all the model details from the two methods you mentioned. I don't know what file types they are since it is NX Nastran and I am a MSC Nastran user.
If you would like, you can post your files here and I can skim them to note any differences.
