Concrete cylinder columns wall thickness
I am looking for design provisions dealing with minimal wall thickness for cylindrical concrete columns. I assume this would probably be defined in terms of a Diameter to thickness ratio. Current problem is a 24 ft diameter column about 40 ft high and supporting large vertical and lateral loadings.
RE: Concrete cylinder columns wall thickness
I'd go with a wall thickness of ...say...about 12 inches.
Well, really, I would probably not go any thinner than 6".  No numbers were crunched to arrive at that thickness..just gut instinct I guess.
It should be called a shaft rather than a column with those dimensions.
Consider a 1 metre strip of wall and design for axial and in-plane shear.
I'd say the min wall thickness in ACI would be a decent go-by as I'm sure the cylindrical shape is inherently stiffer.
I'm not suggesting you use ACI's min wall thickness, just my 0.0002 x 10^4 cents.
Your geometry and loading are similar to that of the concrete pedestals used on composite steel-concrete tanks.  I see that in the Landmark Structures guide specification, they call that out as 8" minimum thickness, on page 9 of this document:
http://www.teamlandmark.com/content/files/CET_Spec_V14.pdf
Agree with ToadJones.  Design it as a wall.
