How do I select a screen position not on the XY plane?
I can't seem to select a cursor location off of the XY plane.  Is there a setting that will allow me to select a point/cursor position somewhere in the Z as well as X and Y?
RE: How do I select a screen position not on the XY plane?
By definition, the 'screen position' (i.e. 'Cursor Location') always lies on the current WCS's X-Y plane.  If you wish to include a non-zero value for 'Z' you will need to explicitly enter that after you've selected an X-Y location.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
A-CAD, I see your question and John's answer. Having taught before I have found the true question may not be what is being asked. What are you wanting to do with an off plane screen pick?
It's OK now.  I got the answer I thought I was going to get and have since found a way to do what I wanted in the program I am writing.
