nx8 multi-part setups + Multi-stage machining and in-process workpie
Hello all. I am using nx to program a multi-part, multi-stage tombstone setup. I am using nx 7.5 but I have access to nx 8. I just spent a very long tome copy/pasting operations from part to part, then having to edit each copied operation to reselect geometry etc. then spent a whole day dragging operations around the program order navigator to minimize tool changes and unnecessary movements. Thinking, "There must be a better way!" I started looking on the Google for a way to instance operations. I came across a brochure for nx 8 advertizing it's great new capabilities for multi-part setups and multi-stage machining, problem is I can't find any kind of documentation on how to set that up. Can anyone here point me to some more info/documentation on how this would be done? Thanks for your time.
RE: nx8 multi-part setups + Multi-stage machining and in-process workpie
Why not program 1 part and use sub programs on the control to repeat the desired tool path at each location? You could have a fixture offset for each part on your tombstone. Then position to the next location with the fixture offset active and call the sub program to cut the part. This makes the program much shorter and easier to manage IMHO.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
Thanks again for the help.
There are enhancements on the horizon that we cannot discuss in this public forum, but they may be exactly what you need. Please log a call with GTAC and ask for information on previewing some of these before their official release. GTAC can also refer you to our Product Manager in the area if needed.
Mark Rief
Product Manager
Siemens PLM
