Assigning planes to a part on SW 2011
Hey everyone. I have a part that I created based on a 3D sketch created from a faro arm. There was no flat surfaces to begin my sketch based off. The part I created though is now completed and has 3 perfect faces to assign front, top & right planes to. I only really need to do this for layout on the drawing. I thought I could assign a plane to a surface with the orientation window but it's not allowing me to.
Any help?
Khris
Any help?
Khris
RE: Assigning planes to a part on SW 2011
Now you will have some options. One will be to offset from a surface. Your offset will be zero.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
