Full path of file on image capture banner
Trying to get the full path to display as part of the banner on an image capture. By default, the image banner only displays the part name.
For example, if I had catPart1 open, it would display catPart1.catPart, I would like it to display v:\engineering\companyName\JOB_NUM\LOT_NUM\REV_NUM\catPart1.catPart.
Its one of those things that seems like everyone would want, I just can't figure out how to do it. I tried all the obvious variable names I could think of, none of them worked. Any help would be appreciated.
RE: Full path of file on image capture banner
Snapshot of $NAME - $DATE $TIME
This should put in the file location and name.
Additionally if you want to add a date or time you can add $DATE and/or $TIME
