How to repair MESH normals for Explicit (Surface to Surface)
I have two contacting surfaces around 200 mm^2 each.  The surface normals are uniform and have the outward positive normal assigned.
After the shell element meshes are made I go to:
Tools -> Query... -> Shell element normals
And all of the elements are highlighted as having conflicting mesh edges.
The simulation runs with out interaction, but I am constantly receiving and error message when I use contact stating that the normals need to be check for uniformity...
Any other ideas?
PJ
