Arc length dimension??
This has never happened before and I can't get it to happen again,but......
I this 1 particular assembly SW keeps giving me the wrong arclength dimension.
Using a very quick and easy (for me anyway) equation that uses 2 arc length 'driven' dimensions I determine what size v-belt I need to use to drive the reel. As I said on all but this 1 occasion it has work perfectly for me.
As you can see from the 2 attached pics, when I select the arc length dimension the value is correct(pic 1) but as soon as I place the dimension, the size changes to what appears to be the short side of the arc(the piece that isn't there)(pic 2)
RE: Arc length dimension??
Here are the pics
I'm not getting error messages
[IMG]http://
[IMG]http://
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
