NX 7.5: place balloons manually
Hi, how can I place balloons manually in a drafting in NX 7.5? Under Insert > Symbol I can only choose 'Custom' or 'Define custom symbol'
Thx
RE: NX 7.5: place balloons manually
Use...
Insert -> Annotation -> Identification Symbols...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Hi John,
Under Insert -> Annotation there is no 'Identification Symbols' in my NX 7.5.
Make sure that you're using a Role with 'full menus'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Hi John,
I checked under Tools -> Customize -> Options and the full menus was already on. Still I can't see 'Identifications symbols' under Insert -> Annotation.
I have it in my menu as well, so there's probably something wrong on your part.
Anyway, you could use the command finder, that way you can at least place them.
NX 7.5
Teamcenter 8
It is really strange that I can not see it in my menu. But oke, that is also a way to find it winky smile
When I said check you Role, I meant to go to the Roles 'tab' on your Resource Bar and make sure that you've selected one which indicates that it includes 'Full Menus'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
