Aluminum valve-stainless steel hose
I have a solid a solid aluminum valve which I am needing to run a air hose from. The air will be 150 psi max. I have so far been unable to find a solid aluminum flexible air hose that has 1/4" npt threads.
The only configuration is a stainless steel braided hose with anodized aluminum fittings. Would this set up not corrode? It is a very expensive valve and I want to ensure no damage is done to it. Below is a link to the stainless hose.
If anyone knows another way to do this I would greatly appreciate it or if this setup will have no corrosion that is fine. Thanks I. Advance for the help, I have no knowledge about metal compatibility and I am trying to learn. Thanks.
http://www.delikon.com/hoseend.html
RE: Aluminum valve-stainless steel hose
Now if you get salt water on the outside it might corrode, but not the internals.
Plymouth Tube
Would the anodized aluminum have any long term affect against non anodized aluminum?
Are you two saying this is my best bet and I should have nothing to worry about? This will be an application wear this will be used for 15-20 years.
Thanks again.
