ABAQUS Restart analysis zero solution problem
Dear members,
I am attempting to perform a restart nonlinear static Riks analasis of a hollow tubular member subject to global bending at the ends. The links below show both the main input file and the restart input file.
I am getting a zero solution whenever I try to run the restart file in the usual way, but for the life of me I cannot work out why. Any advice would be appreciated immensely.
The critical moment occurs at a load factor of approx 1.8. The mesh resolution is coarse in these files so that they run quickly. Symmetry BCs are exploited in the model.
http://files.engineering.com/getfile.aspx?folder=c2bbb2c1-41c2-4a00-8987-44b5ff631d7a&file=GNIA_Rot_2000_S9R5_test.inp
http://files.engineering.com/getfile.aspx?folder=c197e80d-0d5e-4f9e-9b29-798bb54549c4&file=GNIA_Rot_2000_S9R5_test_restart.inp
Kind regards,
Adam
