Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
thesilvert (Civil/Environmental)
22 Oct 11 6:21
Need some advice from fellow engineers or concreters.
Was pouring concrete for some reinforced footings for a retaining wall when the concrete truck, which has been unloaded and pouring along side the job, ending up in the trench/reo we were working on. The idiot tried to drive out instead of reversing back the way he came in, went too close to the trench, it collapse and he got bogged within the reo. Obviously, we couldn't fix the reo and formwork so the pour was cancelled.
Now, we're left with a half poured footing, with the end (the last point of pour) only halfway to the finished level with reo still exposed. I don't want a cold joint since it is load bearing and I don't exactly want to waste more time, man power and hiring an hammer/excavator and rip out what we've already done and redo the whole thing.
Any suggestions or even better, solutions?
bridgebuster (Civil)
22 Oct 11 14:12
Gee, the guy who sits next to me had the same problem recently, and it was a retaining wall too.
Have the designer check shear friction. If it works, you might have to roughen the top surface of the concrete.
dik (Structural)
22 Oct 11 21:22
If the pour is stopped at right angles to the retaining wall, there should be little problem.  Talk to the engineer that designed the retaining wall.
Dik
ukengineer58 (Civil/Environmental)
2 Nov 11 17:52
You need to check with the designer. I would also review your site procedures and set up. The truck shouldn't have been able to fall in.
edstimator (Civil/Environmental)
2 Jan 12 23:49
There are several paint on type glues that will facillitate a permanat bonding of the old and new concrete. The specifications should assuage any lingering fears. I don't have more info than that but a googl search should work.
Hey I hope your ego won't get in the way as mine did under a similar circumstance but i have to agree with UK on this one. As a super or foreman or whatever you need to take responsibility for the accident. I had a sugar sand trench callapse and although I had proper shoring and no one got hurt it took more than enough time for me to realize that I lucked out and no matter what it took, it was my job to make sure that didn't happen and I failed. It was on me and someone could have died. After I owned that, I became a better ...........I don't know, manager?
Accidents don't just happen
they can be avoided with enough due dilligence
Close Box
Join Eng-Tips® Today!
Join Us             Close
