how to make my entire part bigger
hi guys quick question is there a way to make my entire part bigger
i made my part to small, there are too many detail i did oni t, and dont want to remake it in a bigger size and advice??
thanks
RE: how to make my entire part bigger
Why did you make it too small?
I recommend starting over and do it right.
You could Derive Component with Scale factor - but I'll bet you will get unexpected results since you didn't to the part correctly from the start.
Can you attach the file here?
