Oscilloscope integration error
Can anyone explain why my oscilloscope seems to have an error while performing an intergration function? Even when the probe is shorted to itself, there is a ~1.0 mVs/s positive slope to the integration calculation (see attached picture).
I am measuring the total energy used by an electric motor and its supporting circuitry. I connected a 0.1 ohm resistor in series with a battery terminal and hooked up a probe from an Agilent 54266D oscilloscope to either end of the resistor. This way, the voltage output on the scope can directly translate to the current going through the resistor.
I am using the scope's integration function to calculate the total energy used during an actuation and I want to eliminate the effect that this 1.0 mVs/s error has on my results.
Thank you for your help.
RE: Oscilloscope integration error
Gunnar Englund
www.gke.org
