Pipe Support Welded Attachment
Hi this is my first post - When checking local stresses on a welded attachment what ratio should be taken when there are 2 Shoes/Trunnions is it a 50/50 split on all 3 axis? I am supporting below a Relief Valve, fully anchored. I have attached an image of the area concerned.
Graeme
RE: Pipe Support Welded Attachment
You also need a stop in the outletline.
Construction depends on blow-off force,
so you need the designpressure of the system.
Hi yes there is a stop on the outlet - I am only concentrating on the local stresses at the anchor mentioned just wanting to know anyones opinion on how the forces are split when 2 welded attachments are included on the pipe rather than 1.
