Geometry Linking
Geometry Linking
I have the following ...
Assy1
-- Comp1
-- Comp2
Comp1 contains linked geometry from Comp2
I now perform a file-save-as on Assy1, creating Assy2.
Assy2
-- Comp1
-- Comp2
Assy2 opens fine.
When opening Assy1 however, Assy2 also gets loaded. I'm guessing
because the geometry links were created through a top level assembly.
I need to subsequently create Assy3, Assy4, etc ...
Is there any way I can 'correct' the links ?
Only thing I can think of is to create an intermediate file ...
Assy1
-- Sub-Assy
---- Comp1
---- Comp2
Assy1
-- Comp1
-- Comp2
Assy2
-- Comp1
-- Comp2
Assy2 opens fine.
Assy1
-- Sub-Assy
---- Comp1
---- Comp2
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
RE: Geometry Linking
This thread has a discussion about linked bodies using a 2 file technique or a third 'dummy' file.
thread561-241629: Creating a build opposite of an existing part
