How to make a sketch show in a detail drawing?
I'd like to show a sketch used to create a round protrusion cut as a centerline on the detail drawing.  The centerline is needed to convey what the shown sketch dimensions are dimensioning.
In some 3D software, this is a simple "project" command, but I cannot find a similar command anywhere in WF2.  I've tried the "Help" menu, but after perusing many returns, still no answer...
RE: How to make a sketch show in a detail drawing?
Nevermind, got it.  Just turn the curves layer on, then use Sketch > Edge > Use.  Then right click all the new sketch entities and change linestyle to centerline.
