Unit Weight
Unit Weight
Unit Weight
Submerged unit weigh is equal to unit weight (Y) - unit weight of water
I guess Y is saturated unit weight. How can I get saturated unit weight?
When we correlate unit weights from SPT results which one we get? saturated or bulk or dry unit weights?
Thank you for your feedback.
RE: Unit Weight
dry unit weight:  The unit weight of soil when dry
moist unit weight:  The unit weight of soil when moist
Saturated unit weight:  The unit weight of soil when all the voids are filled with water
Bouyant unit weight: The effective unit weight of saturated soil when below the water table.
Use engineering judgement when assigning unit weights from SPT N-values.  They are all based on empirical correlations.  Sometimes you may need to do a parametric assessment to see whether you are tempting fate.
f-d
¡papá gordo ain't no madre flaca!
