odor removing methods in water closet..
what are methods for odor removing in w.c (water closet)?
RE: odor removing methods in water closet..
what is the base of method in Breeza deodorizing toilet seats?
can any body explain this?
Breeza uses an activated carbon air purifier followed by the addition of a scent to mask to odor.
Exhausting the air to the exterior of a building is a more effective approach, especially if you consider the pathogens sprayed into the air from a toilet. The exhaust fan entrance should be located in the vicinity of the rear of the toilet for best results.
