HEC GeoRAS ERROR..HELP!!
Hey everyone,
I am generating a inundation map within HEC GeoRAS. I have my GRID topo data into ArcGIS10 using GeoRAS 10, and have also successfully imported my HEC-RAS model on-top of the topo data.
I go to run my "Ras Mapping" Water surface generation, and everything goes fine. My problem occurs when I attempt to Delineate my Floodplain. Here is the message I get after it runs awhile and then crashes. (see attachment for error message)
Anyone have any idea why I am getting this error? I have tried running the Ras Mapping with a TIN ground surface with the same error. Any ideas??
Thanks!
Thanks!
