Can I add gravel to a non shrink grout for pile head repair?
We are chipping concrete piles, as a result, cut concrete is more than 10 cm from the required level of pile head. Using non shrink grout without gravel is so expensive, so we need to add gravel because of extra thickness of concrete to repair. Can it be practical to add gravel? If so, what is the proportion of cement to gravel mix? Please any expert can give his opinion, is highly appreciated. tnx a lot.
RE: Can I add gravel to a non shrink grout for pile head repair?
thanks a lot for your excellent opinion. But our supplier provide us methods statement which recommend gravel as additional ingredient despite of manufacurer's specs that specifies only cement and water as grout mix.Because of extra cuts that ranges from 10-15 cm, the supplier recommends gravel with sizes about 5 to 10mm. Please explain further. thank you again.
How are you preparing the pile heads? The appropriate way is to saw around the pile, then chip off the interior. If you are chipping without sawing, then in my opinion the piles will be unacceptable.
Any reliable source (Sika, Ciba, etc.) will provide instructions for extending the material IF it is acceptable to do so. There are many good products which allow extending, and many more which do not. In short, if the grout is not designed to have aggregate mixed in, it probably does not bind well and provide strength when you do this. Also, consider the aggregate you propose to use, being sure it does not present an ASR or similar risk.
(And, please stop posting random documents which do not really explain or pertain to the actual job.)
