Flat pattern of contiguous surfaces
Hello, I'm trying to create a label that will wrap around a drafted plastic part, uploaded, and realized it's not just the perimeters of the ends and straight lines connecting them. Is there a way to obtain the flat pattern that would result from unfolding the outer faces? Thanks!
Mechanical Engineer
Field Forensics, Inc.
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Flat pattern of contiguous surfaces
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
