What causes Pro/E WF2 to exit/crash when editing sketch dimensions?
This is a fairly common occurence among users at this location. When it happens, you lose everything up to the last save.
The problem normally occurs after re-entering a sketch to modify sketch dimensions. Double-clicking on a dimension may or may not result in an immediate exit. It is sporadic, and might only crash 5 or 6 times per day. The work-around is to edit all sketch dimensions indirectly using the "modify dimensions" buttons.
What might be the source of this problem?
RE: What causes Pro/E WF2 to exit/crash when editing sketch dimensions?
Hope that helps,
-J-
