Rigid set in sketch
Rigid set in sketch
It looks to me as though you could use the constant length and constant angle constraint on each linear element in the sketch. If you have arc elements it becomes more complex. The fix or fully fixed constraints are too restrictive. This sounds like a good enhancement request for a new constraint.
RE: Rigid set in sketch
Any help?
