12 volt to 240 inverter with 10-25% duty cycle
I am looking for help designing a 12V dc to 240v AC 60 or 120 Hz 1000W inverter whose duty cycle is only about 10-25%. The load is purely resistive.
Ed
RE: 12 volt to 240 inverter with 10-25% duty cycle
Just buy one. Seriously.
The Chinese-origin stuff is available for a fraction of what you would spend on developing your own.
I would buy one if I could find one. The reduced duty cycle is very important but commercial units are all 50% duty cycle for obvious reasons.
Are you using the phrase "duty cycle" in a strange and unusual manner? In the normal use of the phrase, 50% would be more than sufficient to cover off the requirement of 10-25%. I suspect that you need to clarify exactly what you're referring to; is it the waveform itself?
240 volts and 60 Hz is the standard in some localities, but it's not as common as 240 VAC/50Hz or 120VAC/60Hz.
1000 watts is at the high end. You'll be drawing about 100A at 12 volts. It's do-able, but requires heavy gauge wiring on the DC side.
120 Hz? Where did that come from?
I am using 50% as the standard square wave, which can be observed on a scope, 50% positive saturation 50% negative saturation or 50% on 50% off. I want a pulse on (240V) for 15% of the time and off (0V) for 85% of the time and I want the efficiency of an inverter.
Higher frequency 120Hz= smaller transformer.
I assume the reduced time on will be reflected in my DC power draw.
The efficiency of my device (emitter) is much higher at 240V but there is a thermal (power dissipation) limitation.
Ed
When you used the word 'inverter', we assumed you wanted pseudo-AC out, near some standard line frequency.  When you used the phrase 'duty cycle',we assumed you wanted something that could provide rated power for some stated period, with 3x longer rest periods of zero power output to cool off.  As opposed to 'continuous duty', which has enough thermal dissipation to not need rest periods.
We made our assumptions because the word and the phrase used have accepted definitions within a range of trades.  By the way, commercial inverters may use step-up frequencies up to and beyond 20 kHz in order to reduce the size of the magnetics; 120Hz magnetics are not substantially smaller than 60Hz magnetics.
You seem to actually want a pulsed DC output with variable pulse width at an increased voltage.  Or I may be misunderstanding you.
Please try to specify your desires with more precision and detail, without misappropriating standard industry terms.
Mike Halloran
Pembroke Pines, FL, USA
Quote:
...my device (emitter)...
Emitter is one end of a bipolar transistor (emitter, base, collector). You probably mean source, a word that can mean the opposite of sink.
120 Hz is not a standard frequency. So you're unlikely to find an off-the-shelf transformer designed to optimise its capabilities at 120 Hz. 400 Hz is standard in aircraft - so there are plenty of transfomers optimised for 400 Hz. Basically, the standard power frequencies are 50, 60 then 400 Hz. If this is for ground equipment, then you would never be bothered with the extra mass.
How many of these do you require? If you only need one, then you would cobble together some test equipment - perhaps being stymied only at the actual 1000 watt output stage. At this sort of power levels, you'll need some on-site help.
Descriptively I guess I want a pulsed dc output. I can get what I want from my HP signal generator. I set it for 6oHz, square wave, 10 volts P-P, and it puts out a symmetric square wave and indicates a 50% duty cycle. I then select the variable duty cycle mode and reduce it to 15%. I can then use an amplifier to boost the voltage to 240 volts P-P.
I want to do this from a 12 volt battery and I thought an inverter circuit approach would be more efficient. Efficiency is key.
By emitter I mean photon emitter.
60 or 120 Hz does not matter.
Quote:
...photon emitter...
Photon emitter? Light bulb?
May I ask why you need to start with a 12 volt battery?
It sounds like you want +120 volts at 8.33 amps for 15% of the time (1.25 mS at 120 Hz) and -120 volts at -8.33 amps for 85% of the time (about 7.1 mS).  Yes?
And I'll vote with VE1BLL, is there a good reason you need to power this from a battery?
IR emmiter
I need 240 Volts for 1.25mS @120Hz and 0volts for 7.1mS
12 volt battery is all I have avaiable to me in this remote location.
Ed
One approach would start with a standard inexpensive inverter as suggested previously.
Add a full wave rectifier to charge a capacitor to the peak to peak voltage.  This should get you to about 240 VDC.
For your 1000 Watt load that's about 4.2 amps.
I = C * dV/dt, so a 470uF 400V cap will have a little over 10 volts droop in 1.25 mS.  If that's too much, double the capacitor.
To switch the current, maybe a hefty MOSFET or IGBT...
Watch out for ripple current in the capacitor and the fact that this is a lot of dangerous power and voltage to be throwing around.
If one looks *inside* an off-the-shelf inverter (12Vdc to 120 or 240 Vac), there's a possibility (depending on the architecture) that you might find a high voltage DC rail.
There's about a hundred things that can go wrong with this sort of project. If you're not going to bring in a on-site expert, at the very least wear safety goggles to save your eyesight when the capacitor bank explodes.
The confusion was due to wanting a DC source which is switched on and off yet posting 240V AC and 120Hz.
You really want to take 12VDC and convert it to 240VDC and then repetitively switch the 240VDC so it is on for 1.25mS and off for 7.1mS.
You will likely have to build a boost stage to produce a 240VDC bus and then use a MOSFET or IGBT to switch it on and off.
A "pure resistive" IR emitter is still just a light bulb with a filter. There are easier ways to control power to a light bulb. Is there some reason you must have a specific pulse shape?
It works very well. Much better than other waveforms or DC.
Quote (761TJ):
<A specific pulse shape> works very well. Much better than other waveforms or DC.
Based upon what criteria?
Dan - Owner
http://www.Hi-TecDesigns.com
Greater photon density and longer lifetime of source.
Clues about the resistive load would be nice
 is it :-
   a) a spiral tungsten filament, takes a cold surge current
   b) Modern IR LED technology more like a laser
   c) a true  pure resistance ( Measure resistance ?)
Switching a DC rail on/off is much easier than amplifying a Square
 wave !
Quote:
Switching a DC rail on/off is much easier than amplifying a Square wave !
Perfect advice.
