Does PDM make sense for a single user?
I often have various files of different iterations of the same
design. Often I do a lot of "Save As" and after a while....
confusion. I'm a single user without anyone else working
simultaneously on the same files. Would PDM software be
any help...would it make sense for a single user to use a PDM
type system to keep things organized?... or does it seem to mostly
have its benefits for groups of people working with the same files.
RE: Does PDM make sense for a single user?
What type if iterations are you talking about? Could configs not be used?
I've just finished designing one small (20 pieces) assy which went through 7 different design approaches. I assigned a 3 number prefix to the descriptive name of the parts, sub-assys and TL assy and used P&G to create completely independent sets of parts by changing the prefix for each version. When the design was finalised I just "Saved as" each part to it's final part number.
My problem is I'm probably not as meticulous in keeping track of the variations. I do use various configurations in a single file.... but I'm more talking about using totally different design approaches for the same concept... I just don't think configurations would work.....as these different designs could wind up being fairly different from one another. So, I'm wondering if PDM might help keep things organized... but I get what you're saying about the assigning "descriptive names" to the file titles.
I have been using PDMworks as a single user for over a year. I make sure to check all the files into the vault everytime I send out an update. That includes to make prototypes (number revisions) and production (letter revisions). I then save my solid files as steps and add the revision to the end of the file name. I save 2D prints as pdf's with the revision on the end of the file name. My solidworks file names never change so I do not have to worry about which file is the latest revision. By checking the files in when ever I send them out I am always able to go back to the revision I sent someone if need be. I have not used it when I am working on two different concepts simaltaniously though.
I think you can lock the file revision that is used in the assembly revision but I have not tried that. I think once you have "released" the design it might not work but if it is "kept in work" then it might work.
I have PDMWorks but am planning to move to dbWorks because it is more flexible and less temperamental and will perform a lot of mundane tasks.
If you are doing work for others, i.e., multiple customers you have a duty to keep there stuff separate. PDM makes sense. If you have customers that change their minds a lot or don't know what they want (make sure you charge by the hour) you need PDM.
Documenting CAD files is pretty much a well established necessity for anyone doing serious business. If you have the discipline and system to keep this up yourself, and it is possible, fine. But if you find you can't always keep up with it, better get a PDM system. And a good PDM system will add value and save time in setting up parts, assemblies and drawing documents with custom properties and what not that makes drawing go so much quicker.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Dan
www.eltronresearch.com
Dan's Blog
I want to keep revision control, but I have a bad habit of opening up a file, changing it and saving back as the same revision. I have now lost the previous revision and have saved the new revision with the wrong revision letter. Careful habits can prevent this, but I have bad habits. If you have good habits or don't care about keeping old revisions then it does not provide benefit.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Like I said, do it yourself PDM takes discipline and if you don't have it (never make a mistake) then go for it.
As for the learning curve, that frequently involves defining what you do already. This alone can be a great struggle as many people don't really know what they do, they just do it. Nothing wrong with that until the tribal knowledge has to be explained or passed on.
TOP
CSWP, BSSE
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
Although someone here could probably write a macro that would allow you to check all your parts into the vault and close solidworks down at the end of the day so you at least have daily points for the last set of files you were working on. The down side would be any files already closed during the day would not be loaded into the vault. You also might start to eat up a lot of disk space with all the different revisions.
TOP
CSWP, BSSE
The best tool is the one that you understand and achieves your requirements.
Best,
sam
