DESIGN GAS COOLER
DESIGN GAS COOLER
DESIGN GAS COOLER
I need to design a gas cooler. The gas is mixture of HC vapour , water vapour and non condensible gases. At the inlet all the components will be in gaseous state and at the outlet 1% of mass is condensed to water. Please refer to attached data sheet. I find it difficult to how to enter the properties in HTRI . Can any body help.
RE: DESIGN GAS COOLER
missed the data sheet again . . .
why is it difficult to enter properties in HTRI (assuming you are using the HTRI exchanger Suite software)?
-pmover
