Slotted Holes
Slotted Holes
Hi all,
I was wondering if you guys might be able to help me find an item. I'm not sure what it is exactly called, so I'll try to describe it as best as I can.
I have a 1" diameter bolt that is connected through a 6" slotted hole. There is room left over in the slotted hole. I wish to stick this "item" between the bolt and the end of the slotted hole to prevent movement. Does anyone know what this item may be called?
Thanks!
Thanks!
RE: Slotted Holes
RE: Slotted Holes
http://www.FerrellEngineering.com
RE: Slotted Holes
I looked all over this place, but in the end a decision was chosen to use a fabricated steel plug.
Thanks all!
RE: Slotted Holes
If you really need 6" of adjustment, I suggest using the bolts as an erection aid only and field welding the plates after installation. The welded connection should be design for the entire reaction and appropriate eccentricities.
