Alloy 31 ASME SB 625 exposed to chloride at 20 ppm
I am planning to use Magna Flux visible color contrast Dye Penetrant SKL-WP2 to check welds in an absorber that has thin sheets of alloy 31 as a lining. The penetrant cleaner is water.
My question is will the tap water with a chloride content of
20 ppm, adversly affect the alloy 31 when exposed for a short time? ASME SB625 UNS N08031
RE: Alloy 31 ASME SB 625 exposed to chloride at 20 ppm
No. See the information below
http://www.thyssenkrupp.ch/documents/1_4562_e.pdf
