Wellhead Compressor Vendors
Hello there,
I'd like to hear if forum members can recommend wellhead compressor vendors in Europe - companies with good background and references. I am particularly interested in gas engine driven reciprocating machines.
And I have one safety question: can someone advise on the subject of requirement for Fire & Gas Detection System at the wellsite, considering the fact that compressors (as potential ignition source) are installed in the area?
Also, if wellhead compressors are installed somewhere in an intermediate gathering system (e.g. 10 wells entering small separation station), can someone advise what study/analysis should be performed in order to confirm if F&G system is required or not? What is your experience with this issue?
Thanks in advance,
Thanks in advance,
RE: Wellhead Compressor Vendors
I can't comment on what European standards exist for fire/gas or esd systems.
the size of your unit might suggest the better vendor. exterran can do most sizes. CSI is also good, but I don't know their international capabilities.
I've had that discussion with several of my clients, and their answer is often "well it just is", or "exhaust manifold temp is higher than the autoignition temp of methane" (which is occasionally true).
The API 500 exemption for GenSets is interesting. I talked to one of the guys on that committee and his argument was that the engine on the GenSet was an ignition source so it was appropriate for GenSets to be unclassified. I asked him why specifically GenSets and not engine driven pumps and compressors. His answer was "do they run pumps and compressors with engines?".
It may not be universally true that engines constitute an ignition source, but there is a strong belief that they do.
David
