DraftSight (Ubuntu)
DraftSight (Ubuntu)
DraftSight (Ubuntu)
Howdy All,
Draftsight crashes, I see the next error message.
DraftSight Alert
The program must close. Before the program closes, you can try to save changes in:
/home/spidey-westland/Bureaublad/sapstromen_recorver_2011-10-18.dwg
Any changes that are saved are those prior to the last command you used
Do you want to try to save changes?
If I hit "Yes" than close the program.
Hope to see info for this problem?
Spidey_Westland
RE: DraftSight (Ubuntu)
The message told you where your file was stored.
No information was provided about what problem might have cause DS to die.
I have seen that message myself.
Mike Halloran
Pembroke Pines, FL, USA
Howdy Mike.
I've solved the problem.
Installing DrafSight on a +64 laptop or desktop does not good with the automatc deb.
Also the first info of installing was
sudo dpkg -i --force-architecture./DraftSight.deb
But this was not good.
I found on the internet the next command
sudo dpkg -i --force-architecture,depends ./DraftSight.deb
And this command is good.
Now running DraftSight on my laptop and my desktop
regards
Spidey
