ABAQUS Fast Script: change load entity and save .rpt
Hi all,
I would use a fast ".py" script "only" for change an already given LOAD entity (example: from 10Mpa to 15MPa, and after to 25Mpa,...)
so for submit job and SAVE RESULTS in a .rpt file, i can set in gui main options, but changing every time filename.
Could someone put me in the right way to do that?
Some fast example, or online page to read or keywords.. everything is well accepted.
I used only gui, but this time I must handle too much cases for do that manually.
Francy
Francy
