A-arm question
A-arm question
Hey everybody!
Could anyone shed some light on this phenomenon?
I've been taking accelerometer measurements of the A-arms on my minivan (front suspension). Why is it that at higher speeds (65mph) the peak frequency of vibration does not increase with speed, but instead the nearby frequencies will increase. Is this mainly the result of the A arm structural design, or response of the spring and dampers at higher speed?
Any insight would be appreciated.
RE: A-arm question
Cheers
Greg Locock
RE: A-arm question
I've read literature that automotive suspensions are designed with frequencies under 20 Hz for ride comfort.
Is there another reason that driving on the freeway would increase the 10, 15, 18 Hz peaks and keep the 12 Hz peak the same or lower?
RE: A-arm question
You'll probably need to read up on campbell's diagrams, waterfalls, and rotating machinery analysis.
Cheers
Greg Locock
